Originally posted by HIGHLIFEII
How many hours on the props in 4 years?
Originally posted by MichaelNJ
I'm having mine scanned after about 4 years (I think, maybe more) with no issues. Be interesting to see how they are. I asked my mechanic and he had a good suggestion. He said to place a hacksaw blade or something on the face of the rudder with the other end just touching the edge of one of the prop blades. Then turn the prop and see how the other blades contact the blade. It's not precise but it will give you an idea if any of the blades are out. You can do it in a few positions along the blade.
This method doesn't replace a computer scan of course. It will just give you an idea if a blade is significantly off. Realistically, on a 30-40 foot cruising boat, as opposed to a performance boat, if there are no vibrations or noticeable changes in performance, RPM, Fuel consumption, why spend several hundred dollars tuning props just to get them perfect?
