- Dec 9, 2006
- 24497
- 113
I just installed my new set of Bravo III SS props after having them polished. I bought both props on Ebay in separate auctions as new old stock. After going for a ride today I am unimpressed with the performance with them. See test results below
My boat has a 2001 5.7L 260hp engine in it and with the original props it runs around 4,400 to 4,500rpms at full throttle and is running 47.5mph (all speeds are by GPS). At 3,000rpm I run real close to 30mph if not right at 30 and at 3,600rpm it's between 35/36mph. This new set is a bit different. At full throttle it's running 4,900rpms and is only going 43.4mph. At 3,600rpm I was only able to get 32mph and at 3,000rpm I was running 25mph.
These props have the same part numbers as the original props why would these not run at least closer to the same? I'm thinking these new props are underpitched for my boat, but they are labeled as a 24 pitch prop?? what gives?
