While a towing service is nice to have, you should always be prepared for being able to help yourself if you have to. Don't always depend on someone to come rescue you right away. Help from a service may be hours away and you may be up on those rocks in 15 minutes. If there is another vessel in the area that can safely help you, take advantage of it.
One thing I can think of, is that depending on the configuration of your bow roller, you have to make sure that an almost horizontal lead from your anchor rode does not allow the rode to jump from the roller or chafe more aggressively. Actually, ideally, the rode should be led to some sort of bridle, whose legs can be brought up through chocks and secured to backed cleats. Avoid putting the stress directly on the windlass.
EDIT: I now see you have all chain. Even easier. Just take a snubber (two preferably, to form a bridle) and lead it/them to the bow cleats. Be sure the cleats are backed and strong enough for this purpose. The snubber lines and shackles should be strong enough for the entire load, as they will take the stress of the tow off of the windlass.
