PropsI
kayaker
I just cleaned my props on my boat,they look new again.Last year I painted them with antifouling paint.What do most of you use?
Doesn't matter what anti-fouling paint you use, as it won't last long on running gear. From what I've seen and heard, Prop Speed is about the only product that really works on running gear.
You might want to ask this on ATC. It's really not a SeaRay (or any brand of boat) issue.
Kayaker, what did you use to clean the props to make them look new?
Davefin
My props had a lot of paint on them,they looked bad.I used a dremel tool to get all the paint off.I polished them and used some brasso.
Leo
Prop speed is probably the best to use on all running gear. but no matter what you use it will eventually burn off the props. I used it this year on my IPS drives. Cost.. $400 per pint.....
