Here are the details if you are interested or curious:
GPP MARINE COVERAGE DESCRIPTION
Genuine Protection Plan (GPP) Covered Components & Covered Assistance Service
Engine: All internal lubricated parts contained within the block to include pistons, piston rings, pins, connecting rods, rod and main bearings, crankshaft, camshaft and bearings, followers/lifters, push rods, rocker arms, rocker shafts and bushings, rocker arm cover(s), oil pump and pickup, oil pan, engine mounts, flywheel and ring gear, balance shaft(s), valves, valve guides and seats, valve springs and retainers, cylinder heads, cylinder barrels, intake manifolds if damaged by a covered component. Lower Unit: Internally lubricated parts contained within the gear case including forward and reverse gears, pinion gears, clutch dog and dog pin, cam follower, prop shaft, driveshaft, bearing and bearing carriers, gear case if damaged by a covered component. Transmission: Internal lubricated parts contained within the transmission housing. Clutch plates and clutch drums, thrust plates, planetary gears, shift bands, reduction gears and bearings, shafts, bearings, hydraulic pump, hydraulic pistons, valve body, transmission mounts, oil pan. Lubricating System: Complete oil injection system including oil pump, oil injection driveshaft and gear, oil tank reservoir, oil lines, and level sensor. Steering: Control helm assembly, control rack and yoke assembly, power steering pump, power steering cylinder, steering main and intermediate shaft, U-joint, wheel hub mount, steering gate, nozzle or rudder, hydraulic steering head, hydraulic cylinders and flow valves. No coverage for cables or pulleys. Jet Outboard Drive: Internal lubricated parts contained within the pump housing. Driveshaft, shaft bearings, shaft coupler and flex disc, mounts. Jet impellers and liner are not covered.
Pump Drive System: Internal lubricated parts contained within the pump housing. Jet impellers and liner are not covered.
Controls: Shift and throttle control box parts to include: Cams, shafts, pivots, bushings, housing, control arms/levers or knobs, engine mounted shift control cable and throttle control cable. Neutral switch, starter/stop switch (excluding key/lock), horn button.
Power Trim: Trim and/or tilt motor, trim cylinders, cylinder mounts and pivots, trim motor actuator solenoids, control valves, reverse leak valve, trim and/or tilt wiring harnesses, trim and/or tilt master control switches, manual trim cylinder and manual trim cable.
Fuel Delivery: Fuel delivery pump (mechanical/diaphragm), carburetor body, air box (silencer/flame arrestor), and electric choke solenoid.
Electrical: Alternator, starter, starter solenoid, voltage regulator/rectifier, terminal blocks, starter switch, and windshield wiper motor.
Ignition: Power pack/switch box, ignition coil, ignition amplifier/module, ignition trigger and pickup sensor, ignition switch, and rev limiter.
EFI/DFI Engine Management System: Fuel injectors, fuel distribution(s), fuel injection pump, fuel delivery pump, ECU (Electronic Control Unit), throttle position sensor, idle speed control, air flow sensor, detonation sensor, coolant sensor, and ignition pickup sensor.
Seals and Gaskets: Are covered in conjunction with the mechanical failure of covered components.
Towing Assistance: If while in water, towing becomes necessary due to the breakdown of a covered component, we will pay up to $225 for tow.
Hoist/Lift Out Assistance: Should it become necessary to hoist/lift out the covered boat due to the failure of a covered component, charges will be covered up to $200 on boats larger than 26’ in length.
Optional Packages Covered Components
Fisherman Package (F) Covered Components: Battery main switch, battery isolator, battery selector switch, battery box, fuse block, volt meter, battery charger, electric horn. Electric trolling motor and the foot control unit and control switches (applies to one unit only). Power transom/manual transom lift motor, its slides, jack screws, hydraulic cylinder, and control panel. Anchor, its winch and guide (excludes rope, cable or chain). Fish finder, its transducer, speed and temperature sensors. Digital depth finder readout and sensor. Lake water temperature gauge and sensor (hull mounted only). Compass head including digital display. Speedometer head, speed log, and cable.
Luxury Cruiser Package (S) Covered Components: Auxiliary Powerplant/Generator Components: All internal lubricated parts of the powerplant engine, its starter motor and switch, power inverter/converter. Air Conditioning/Heat Exchange System Components: Compressor, evaporator, capacitors, relays, thermostats, fan motors, control panel, expansion valve, temperature control programmer, receiver dryer, and heating element. Fresh Water System Components: Water pump, compressor, fresh water tank, water lines, traps, fittings, faucets. Hot Water System Components: Thermostat, relays, water heater unit. Waste System Components: Shower, toilets, sinks, fixtures and traps, and connections. Appliances: Range/cook top, oven, microwave, refrigerator, icemaker, trash compactor, central vacuum system. 12 Volt/24 Volt/110 Volt Shore Power Components: Battery charger, converter, onboard receptacle, shower power main switch, circuit panel and circuit breakers (shower power cables excluded). Electrical Components: Battery main switch, battery isolator, battery selector switch, remote spotlight, bow, marker and running light assemblies (light bulbs are excluded), control panel and switches. Dual Station/Tower Control Components: Helm control, throttle speed control box, speedometer head, tachometer head, speed log and speed sensor. Gauges: Voltmeter, fuel gauge, trim position gauge, oil pressure gauge, water pressure gauge, engine water temperature gauge and depth gauge. Bilge Components: Pump, manual control panel, bilge blower and sensor (shutter), control switches. Anchor Control System: Winch, electric windless motor, bow pulpit guide and switches.
Supercruiser Fisherman Package (SF) Covered Components: Includes all items from coverage (F) and (S) above.
Navigation Package (N) Covered Components: GPS receiver, GPS processing unit, antenna, video display screens, controls and switches
Non-Covered Components and Non-Covered Failures: Only those items under “Covered Components” are covered. The following reasons of a breakdown are not covered, even for covered components: Incidental or consequential damage or loss caused by a breakdown of covered components including property damage, physical damage, death, personal injury, inconvenience, loss of use or time, loss of profits or wages, travel expenses, commercial loss, punitive or exemplary damage, attorney fees. Repairs covered under the original manufacturer’s warranty, regardless of if it is still in business. Losses covered under a manufacturer’s recall, factory notice or update program, or, if the vessel is covered under another service agreement, guarantee, or policy. Repairs required due to collision, impact, grounding, abuse, neglect, negligence, misuse, modification, alteration, explosion, vandalism, riot, upset, windstorm, environmental damage, debris, bellows and/or sealing boot rupture, animal/insect damage, aquatic growth, seaweed, algae, barnacles or zebra mussels, salt, sand, dirt, flooding, condensation, mold, lightning, hail, theft, fraud, tire, war, acts of God, or, loss that is normally covered by Casualty Insurance. Vessels used in racing, competition, or commercial/business use. Breakdowns resulting from chemicals, smoke, soot, sludge, carbon or “coking”, corrosion, rust, electrolysis freezing, contamination, overheating, or, operation of the vessel without the proper levels of lubrication or fluid type. Failure to perform the manufacturer’s recommended maintenance. Excessive oil consumption, loss of compression and the gradual reduction in covered components due to normal wear and tear. Damage caused by continuing to operate the vessel while components have already failed. Any failure resulting from submersion or ingestion of water entering the engine through the air induction system or exhaust system including the failure of exhaust flapper valves, cracked or corroded manifolds or risers. Loss caused by external water inlets or outlets and internal water passages being restricted or motor/drive mounted too high. Service adjustments and cleaning, reverse polarity, reprogramming, refrigerant, coolant, lubricants, fluids, misc charges, shop supplies, hazardous waste removal charges, belts or hoses. Seals or gaskets due to seepage or overheating. Any claim not authorized in advance by Genuine Warranty Solutions. Removal or replacement of bulkheads, deck, hull, gear equipment, or any material for the necessary access to the vessel/engine. Non-factory installed components and items not originally on the vessel at the time it was sold new.
GWSIGPP03/05/10
