radio problem again
ylerner
Hey guys,
When my radio is loud it shots off, also when it's on playing, with every beat the illumination dims even if the radio is on low volume. And on top of that, boat started to choke with all the gauges going dead. Then when you press reset button it resests the electrical system and it's fine. It means the system gets overloaded right? What can I do to test it. The radio hooked up as follow: red to red fused, yellow to another red from battery and the speakers are also hooked up normaly both grounded and the main ground to the radio going to one of the gauges's ground. Please help with an advise. It's 93 glastron, 18' volvo I/O
