#1- carrying a dozen jugs of water on deck ? as if sailboat weren't already cluttered enough...
i could understand that on a boat cruising the bahamas but I see boats cruising the keys or ICW doing that... why can't buidlers find space to add water tankage !!
#2 - no rubrail. I see a bunch of sailboats with no or insufficient rub rails... why is that ? from what i see it's not like the average blowboater does a better job docking !
Pascal inserted a smily into his thread title - so, I suppose he's just poking fun at the expense of the three or four sailboaters in here.
Those "ragbotes" you see with jugs on deck, are most likely cruisers - "living their dream", on inappropriate boats for doing so. You didn't state the types of sailboats with a "dozen jugs of water on deck", but it would be my educated guess they were coastal and inland cruisers, such as Beneteaus, Hunters and Catalinas [Benehunterlinas]. Most models by these makers are designed as day-sailers and weekenders, with small watertanks.
Take a closer look at bluewater, cruising sail boats and unless living permanently on the hook - they will have ample tankage. These types are of higher quality, construction - obviously costing more when new, so living the dream on these boats is further from reach for some.
Re: rubrails - look closely and you'll see they're there, typically small, monochromatic plastic strips, cleverly incorporated into the hull design - mostly found on Benehunterlinas to protect the cheaper, fragile hulls.
Many offshore cruising sailboats have them, but typically of heavier rubber, stainless material, or even teak on older vessels.
The vast majority of sailboats without rubrails are the racing hulls - built to be light and fast. Rubrails would add weight and be uncomfortable against the butts of railmeat, hiking over the windward side.
My boat has a 140 gal water tank and a substantial rubber, perimeter rubrail secured beneath the teak toerail. No water jugs on my deck thank you. It is however, a high quality 9 ton bluewater cruiser.
Oh, and Brett, yes - we love our wine and cheese, but please, no colby and reisling for us. That is, unless we're entertaining our powerboat friends. ;-)
Steve
