Re-powering
In the know
Yes sir, the Crusaders are getting tired and it is that time to start thinking re-power. In order to realize more efficiency, I am going from gas to diesel and from twins to single. Rather than launch the boat today as planned, I have instructed the yard to begin hull modifications to fit my new singel diesel. The goal is to have all work done by August 1st and run sea trials first weak of August. It will take some dedicated hard work, some thoughtful modifications to the hull, but I think we can get my new Wartsila-Sulzer RTA96-C in by August.
The Wartsila-Sulzer RTA96-C turbocharged two-stroke diesel engine is the most powerful and most efficient prime-mover in the world today. The Aioi Works of Japan's Diesel United, Ltd built the first engines and is where some of these pictures were taken. It is available in 6 through 14 cylinder versions, all are inline engines. These engines were designed primarily for very large container ships. Ship owners like a single engine/single propeller design and the new generation of larger container ships needed a bigger engine to propel them. The cylinder bore is just under 38" and the stroke is just over 98". Each cylinder displaces 111,143 cubic inches (1820 liters) and produces 7780 horsepower. Total displacement comes out to 1,556,002 cubic inches (25,480 liters) for the fourteen cylinder version.
Some facts on the 14 cylinder version:
Total engine weight: 2300 tons (The crankshaft alone weighs 300 tons.)
Length: 89 feet
Height: 44 feet
Maximum power: 108,920 hp at 102 rpm
Maximum torque: 5,608,312 lb/ft at 102rpm
I think "You need a bigger boat".
You going to hook it up to a B-3 or to a VP duo-prop?
Ken
I think the 6 cylinder should sip fuel compared to those Crusaders!
I'm not yet ready to sacrifice the reliability of a twin engine rig.
/s/ Real Ole Salt
Should I use synthetic oil in that?
That should drop in with no problems. You might have to align the shaft.
You really need to consider what type of boating you do and whether the hours per year warrants the fuel savings of a diesel. Gas may be the way to go, or so I'm told...
I would really recommend a jet drive propulsion so that you can minimize your draft.
I wish I could get it in a one cylinder version. 7780HP is more than enough for my boat.
One nice thing about that conversion, you get a new engine AND a new tuna tower.
And just think of all the antennas you can mount up there.
after it's in let's compare performance numbers.
