Mike, you can buy 1/16" thick x 1" wide aluminum angle from hardware stores and places like Home Depot. It comes in approximately six foot lengths that can be cut with a hack saw. You attach it to the sides of the cabinet with short sheet metal screws or pop rivets, with the other part of the angle flush with the front of the fridge, and pointing away from the fridge. Then you drill and screw it to your surrounding cabinetry (countersink your drilled holes, and use flat head screws so that the screw heads don't protrude out). If it looks like crap that way, you can then add molding over top of it, and wind up with a nice, neat professional-looking job. I did a job one time, using flexible plastic automobile side trim from Pep Boys, where you peel off the paper from the back side of it, and stick it on. Looked good when it was done, with mitered corners and all. If you're careful, you can cut it with a razor knife.
