Removing bellows sleeve on Bravo I.
BillWilliams
I need to replace the trim limit switch on our Bravo I outdrive. According to the instructions I've read, I need to remove the gimbal which means I have to disconnect the bellows.
Can the sleeve which holds the bellows in the gimbal be removed without the special tools recommended in the instructions (without destroying the sleeve or bellows mind you)? Or do I have to byte the bullet and buy the tools for something I might do every 10 years?
