I'm replacing the bow hatch on my 1985 Sea Ray Weekender and I have two questions:
The new hatch came with a strip of rubber-like gasket material that is designed to be cut to size and installed between the fiberglass deck and the hatch frame. My original hatch only had sealant between the frame and the deck - no gasket material. I'm tempted to leave off the rubber-like gasket because I question whether it will actually help or harm the ability to seal properly, and whether it will degrade over time. Has anyone had experience with this?
Also, the holes in the new hatch frame do not align with the holes in the deck from the old hatch frame. Drilling new holes in the deck is no problem for most of them, but one of the holes in the new frame partially overlaps one of the original holes. If I fill the original hole with epoxy, then try to drill through (half would be in the epoxy in the old hole and half would be creating a new hole), will it drill okay, or will it just tear the epoxy out of the old hole?
