Originally posted by KiDa
Originally posted by RWS
.....additionally I will never again own a gasoline generator. period.
Why?
I owned the factory installed
carbureted 6.5 kW Onan MCCK.
the first reason is reliability.
As we use the boat for numerous overnights on the hook, the second reason follows below
THE RISK OF CARBON MONOXIDE
A couple in Michigan arrived at their boat last October, started the gas generator, turned on the boat's electric heater, and set to work on a few end of the season projects. While they were working, carbon monoxide (CO) from the gas generator began creeping quietly into the main saloon somewhere down in the bilge.
Without a CO alarm, there was no way that the couple could have been aware-or even had the tiniest hint--that the deadly gas was mixing with the oxygen in the boat's cabin. CO is colorless and odorless, and it produces initial symptoms-drowsiness, headaches, nausea, or dizziness--that aren't especially alarming.
The unsuspecting couple soon "fell asleep," and would have died had it not been for the early arrival-almost two hours early-of their son. He quickly shut off the generator, opened ports, and phoned the rescue squad. They were extremely lucky; most CO claims have a much sadder outcome.
An investigation afterward concluded that the CO had come from a drain plug in the generator's muffler that had worked loose and lay in the bilge. The report also noted the lack of a CO detector aboard, which wasn't a surprise.
Of a dozen or so recent claims for CO fatalities or near fatalities in a boat's cabin, the lack of a CO detector is the only thing that all of them had in common.
CO can enter a cabin from many different sources, according to the claim files: from a hot water heater; from a galley stove; from the "station wagon effect"-exhaust from the boat's exhaust; from a generator; and even from other nearby boats. There have also been several injuries from people swimming under swim platforms when an engine or generator was being operated.
Certainly it is important to recognize the symptoms of CO poisoning: headaches, drowsiness, and nausea. With most of the BoatU.S. claims, one or more of these symptoms were present, but victims did not recognize the danger they were in.
It is also advisable to inspect the engine and generator for leaks in the exhaust system and to avoid, or try to avoid, the many different situations that could bring CO into a boat's cabin.
That isn't easy. Besides the station wagon effect, accidents have been traced to wind direction, proximity to a dock or seawall, boats rafted together, an open hatch or port, a canvas cover, or combination of several causes.
It isn't unusual after an accident, for an inspection to spend many hours, or even days, trying to ascertain how CO got into a boat's cabin.
While guarding against the many possible sources of CO is certainly advisable, the most reliable safeguard is a CO detector. As of August 1, 1998 the American Boat and Yacht Council (ABYC), the organization that writes the voluntary standards for recreational boats, began recommending that all boats with enclosed accommodation areas and a gasoline generator or a gasoline inboard propulsion engine have a CO detector installed.
(Diesel engines are not included because they are much less likely to produce deadly levels of CO.) The recommendation that CO detectors be installed on new boats is great news for anyone who will be buying a new boat, but what about boats built before August 1998?
INSTALLING A CO DETECTOR: A FEW CONSIDERATIONS
One reason that ABYC may have been slow to recommend the use of CO detectors may be their reputation in the past for emitting unnerving false alarms periodically. You could almost count on a CO detector made prior to 1992, the older "single point" alarms, to sound whenever they detected even the slightest trace of CO.
Since a whiff or two of CO is likely to drift into a cabin several times a day, the frequent alarms were an ongoing nuisance. After 1992, however, manufacturers began making more technically advanced units that use "time-weighted averaging" to greatly reduce the number of alarms.
By averaging the CO over a period of a few minutes, these newer alarms will not sound unless they repeatedly detect CO.
Some of the newer units can even do things like disengage the generator if CO is detected. A proper marine CO detector, incidentally, will have the UL 1524 marine mark, which means it was tested by Underwriters Laboratories standard 1524.
ABYC does not say where on the boat a CO detector should be located. The gas, which is about the same weight as oxygen, tends to dissipate evenly in an area and isn't any more likely to be found up near the ceiling or down by the cabin sole.
As a practical matter, placing an alarm at eye level allows you to easily monitor any meters or warning lights on a unit.
Sleeping areas, main saloons, an enclosed fly-bridge, and anywhere else people spend time are candidates for a CO detector. Areas that should be avoided include near hatches or doors where fresh air might distort readings. Dead air spaces-corners-should also be avoided.
TAKING CO DETECTORS SERIOUSLY
While the older alarms were often a nuisance, the improved technology means that when a newer alarm sounds it should be investigated.
CO that drifts in and out of a cabin can be dangerous, since the effects of CO are cumulative and can build up gradually in a person's bloodstream over hours or even days before it reaches critical levels.
This is true even if when the person breathes fresh air periodically; the CO remains in the bloodstream. How quickly the CO builds up is a factor of the concentration of the gas being inhaled (measured in parts per million [PPM]) and the duration of the exposure.
The half-life of CO is approximately five hours, which means that it takes five hours for the level of CO in the blood to drop to half its level when exposure was terminated.
There is also some recent research challenges traditional thinking that the effects of CO poisoning are transitory. Studying 96 victims for one year beyond their exposure, researchers found over 25% showed evidence of brain damage 12 months after exposure. These long-term CO injuries can include apathy, memory loss, inattention, and depression.
How Much CO is Too Much? (In Parts Per Million (PPM)
• 200 PPM Slight headaches within two to three hours.
• 400 PPM Frontal headaches within one to two hours.
• 800 PPM Dizziness, nausea, and convulsions within 45 minutes. Insensible within two hours.
• 1,600 PPM Headache. Dizziness and nausea within 20 minutes. Death within 30 minutes.
• 3,200 PPM Headache and
dizziness within five minutes. Death within 30 minutes.
• 6,400 PPM Headache and dizziness within one to two minutes. Death in less than 15 minutes.
• 12,800 PPM Death in less than three minutes.
CO Concentration at the Source
• Gasoline Engine 10,000 - 100,000 PPM
• Diesel Engine 1,000 PPM
