Originally posted by Brian N
Next he needs to safely get the windshield off, I'm sure we'd never find a replacement...
As you can see, the windshield is held in place with the "hooks" through the windshield then through the hull. It's a tough situation either way. Try to unscrew it from the hull and the material is corroded, you may crack the windshield from the torque applied to the nut and bolt assembly. Try and remove it from the top and the angle for the screwdriver is insane. DAMHIK
IF (big IF) you can hold the bolt assembly with vice grips or the like and remove from under the bow, you may be better off. Then you can gently pry it with a plastic plaster knife or the like. I imagine there is a lot of crud holding it to the hull.
Good luck. I'm sure you would rather help him than work!
