Originally posted by mdoherty
700 hours about the equivalent of 2 years in a car. You wouldn't be thinking about doing anything with a two year old car would you?
The only thing you could check is to make sure the belts are tensioned properly (not too tight) which can cause bearing wear.
Originally posted by GeeBee
While we are here on this subject, you need to understand the "Waddington Effect". By doing un-necessary preventive maintenance you are actually decreasing reliability, not increasing it.
http://www.mariner-usa.com/blog/the-origins-of-predictive-maintenance/
http://blog.aopa.org/opinionleaders/2014/01/14/the-waddington-effect/
