RPM'S
wannasail
i have a 1995 Bayliner Ciera Model 2355 ,i have been having problems with rpm's, First i find it very hard to get on plane, and when i do sometimes the rpm's go crazy, like to get it on plane i give full throtle untill on plane then lower the RPM'S to about 3500 but at that it wants to come off plane again, then when i give it more throtle to stay on plane the RPM'S jump around like crazy like 3500 to 5000 without touching the throtle . when it reads say higher RPM'S then i want like around 4000 to 5000 the engine still sounds great and there is not a strain on it it sounds normle, but needle is like i said to high, any ideas what it could be
Sounds like your tach is defective and needs to be replaced.
What engine do you have and what is the recommended WOT RPM?
I'm guessing you have a 5.0 or maybe even one size smaller.
Maybe you have a slipped prop? Pull the prop and have it checked/replaced.
I have 5.0 305 with alpha outdrive and a stainlees steel prop that is new and the hub is not spun for sure
Does the RPMs actually go up or just the tach read a fluctuation.
Like Liz said...
If the engine is in fact going up/down in RPMs, you either have a spun coupler, prop hub or your prop is bent or out of specs so that it's cavitating.
