Originally posted by Sandy
Originally posted by JVM225
I'm interested to hear if this worked. The true test will be away from the dock and under load. I can understand how crud in the system will cause a motor to run hot, but in the description of the symptoms you mentioned steam in the exhaust. Steam in the exhaust is a symptom of water in the combustion chamber.
Steam quite often (and a lot more often than water in the combustion chamber) happens when RW flow is for any reason insufficient to cool exhaust temps below 212*F, so what water is still injected into the riser outlet will flash to steam almost immediately and be noticeably visible in the exhaust.
Bad RW impeller, restricted RW intake or strainer or cooler or heat exchanger or riser/elbow are some of the RW flow related things which can cause steam in the exhaust of a FWC engine.
