- Oct 20, 2002
- 10503
- 3,677
Rust Removal is a common question. A lot of products are out there for Rust Removal. This thread is on a Cheap (Cost Reduced) method.
I ran across a set of comments on using Sugar Beets and also a Mixture of Molasses.
Here are some quotes from other sites:
"I have used the super-simple electrolytic rust removal method many times with excellent results. No sticky mess that way and no expense.
- Battery charger, scrap steel sheets, washing soda and tap water.
And the solution can be reused again and again."
(this one's on the Molasses mess)"3 to 1 is what I use, should be done in a week. It will clean areas of those wheels even sandblasting won't get. Cleans gas tanks like new, and kills the gasoline so you can solder/weld them. The whole piece has to be submersed or the gas from the juice will REALLY rust what's sticking out of your tank. I wash and scrub with Spray Nine and a brush and rinse, rinse, rinse. I have stuff laying in my shop for a year without primer after derusting that hasn't started to flash. The feed store stuff is made from red beets, the stuff you eat on pancakes is made from corn. All the rustbeeter guy is doing is getting rich."
What do you guys know about this stuff?
Have any of you actually used the Beets or Molasses method?
I was really interested in the Elyctrolytic process.
