As winter looms here in NC, I'm told it doesn't get cold enough to do a full winterization and that a space heater will prevent freezing on the coldest days. That said, I understand there are specialty engine room heaters, that... of course... are more expensive than regular heaters. No thanks. What I want to know is what constitutes a "safe" onboard heater? I'm sure the ones with exposed coils are clearly not a good choice... Duh. But what do I want to look for in a heater to prevent hard freezes? Ceramic, oil, alcohol (don't think I want to use oil as the fuel, but I don't know what circulated in the sealed fins of a radiator type electric heater)... Digital thermostat, timer, will a dial timer like you use for lamps when on vacation work? I don't want to waste a ton of power either. What makes the engine heaters so special because I am planning on using a small room heater with an engine cover open to prevent freezing.
Thanks y'all.
Thanks y'all.
