- Mar 5, 2001
- 3655
- 1,800
Billy, my records indicate that you paid $929.00 (plus shipping) for the head. Yours is in bone, and flushes with pressure water.
Right after the first of the year, our auditors discovered that on the raw water flushing heads with the remotely mounted pump, we'd made a mistake on our pricing and we weren't making anything on the raw water units. So the pricing was adjusted upward on the raw water units only. The current factory retail price is $1160.00 for white, and $1190.00 for bone. These are the top-of-the line units with the 4 button Smart Switch control. On factory retail pricing, the 3 button manual switch system is $200.00 less, and the single push button manual version is $300.00 less than the 4 button Smart Switch version. The pressurized fresh water units remained the same price as was originally set.
I strongly recommend the Smart Switch control, not because it's more expensive and I want to spend your money; but because it is a lot more flexible. You can program it to your particular needs, and it will flush that way every time you use it. If your needs change, it can be re-programmed to meet the changed needs. The Smart Switch (4 button version) has three short flush bursts, rather than a single continuous one. This enables it to flush thoroughly while using a very small amount of water. With it doing it 3 times instead of just once, it gives any entrapped air time to work its way out, and dramatically improves the efficiency of the head.
The other two switch methods are manual - you must press and hold the button in, for it to do anything. And it runs a continuous cycle, air and all, while you're holding the button in; no three burst flush...
