I own an 02 290 Amberjack with the fishing package. I bought it new and have over 500 freshwater hours on it. It has twin 305,260HP engines with Bravo III drives turning 20" pitch set propellers. It is just my wife and I and we prefer the bigger cockpit of the AJ over the sundancer. I had some initial problems with the boat, mostly minor stuff, but still a hassle. I think I got a Monday boat. I have owned 6 Sea Rays and never really had any problems with them.
I also have a generator, had a couple problems with it, but it runs beautifully and is very quiet. My boat runs out at about 40 on the GPS and cruises at 28 turning about 3700 RPM.
The boat has a bigger feel than it is and is very ease to maneuver around docks. Being inland on Dale Hollow lake in TN. I can not tell you how it handles in rough water, but it rides well where I use it. I had a 270 Sundancer before and there is no comparison in the ride. The 290 is way better.
You say that the 290 is a little big for you, but if you can afford it, I would buy the 290 especially if you are going to leave it in the water and not try to trailer it. I would not go with the V-Drives in it because from what I have heard it does not perform well and is harder to work on because of the room the transmissions take up in the engine compartment. With the IO's you have room to get in to most systems.If you can, check both out and see what I mean. The advantage to the
v-drives, especially in saltwater, would be the maintainence factor of the outdrives (more susepticle to corrosion).
I would reccommend finding one with 350's versus 305's because the bigger engine has more torque, will get out of the hole faster and hold you on plane at lower rpm's. Fuel comsumption would be about the same.
Would I buy another one, you betcha, just wish I had gotten off to a better start with this one. All is well now, it just took some work. I hope that we can some day buy a used 34 Amberjack and that would be my last boat (getting old).
I hope this helps you out and be glad to try and answer any other questions you might have. My e-mail address is rrol3935391rb2@gr5taol.com
Good luck,
