Long story.
Two years ago my 2000 Merc 5.7 blew up. Over the winter of '12/13 I bought and had installed by my marina (a Merc dealer) a new (Mercury Reman) 383 magnum MPI. Wonderful motor - about 100hp more then the tired 5.7 carb I had - the joy of fuel injection start right ups, etc. Until about 50 hours when it developed a knock. After about a month of trying to figure out if the knock was coming from the sterndrive, the transom, etc, we finally tracked it down to the motor. (I had a post here about it) Merc sent out a field engineer who went for a ride with me, and said, "Yep, its got a noise" - he suggested that it may "go away" as it breaks in more, and that I use it the rest of the season and see what happens. He also said they would replace the motor for me, if that's what I wanted.
So end of season comes and the noise is still there. Being the skeptic that I am, and NEVER having had a brand new motor make a noise like that, I opted for the replacement.
Fast forward to this April. New motor installed over the winter (no charge to me) - I come to the marina the day its dropped in to move it over to my slip. Go to start, it turns over but no start. 10 seconds of starter, no start. Having had MPI motors before, I know its a turn the key and it starts right up situation. However to get it started I basically have to give it about 1/3 throttle to get it to catch. I let the marina know. This now goes on for about a month, replacing the harness connector from my boat to the motor, replacing the ICV, nothing. All along I'm suggesting its a ECM (or PCM as Merc calls it) which they finally do. They tell me that the old PCM is marked "Freshwater cooled" which mine is not, but that shouldn't matter I don't think. Anyway, with the new PCM it starts fine. I didn't open it up during the first 10 hours for break in, but once the new PCM was in, and I was at about 13 hours on it, I opened it up one time to test it out. Would not reach WOT RPM's. Only would get to about 45-4600 rpms. Took about 10 seconds to get on plane. This is a 24' Crownline 242 BTW - the previous knocking motor would hop up on plane in about 5 seconds and WOT at 5000 RPM - right where it should be according to spec, which is 48-5200. Motor is definitely making less power then the previous. Note: Same weight on the boat, in fact the fuel tank was only at 1/4 when I tried the WOT. No additional people, or load. I think the exhaust smells a little rich when idling, but that could be my imagination.
So I asked the marina to reach out to Merc and see what they can do.
Which I suspect is going to be nothing, since the motor does run ok, just underpowered. Too bad there's no Dyno for boats...
Any suggestions on how to address this with Merc?
Thanks, and sorry for the long winded story.
Edit: Just to mention, I had been through a couple half tanks of gas during the first 13 hours - all that rpm varying during the break in plays havoc on gas consumption, so it's fresh gas...
