Originally posted by Ghost
Cap Bill, seriously, 28 amps is the same as 30 in any practical world. I think you just like to argue for arguments sake, boredom or just plain rude pot stirring. But you make the point. The Marinco 30 amps is on day 1. A device only built to handle 30 amps on the day it is installed is not worth having and given a marine environment, I would say irresponsible at best and criminal at worst. Ask the liveaboards who just barely got out.
That's why I upgraded to a unit that is built to handle much more than 30 amps on day 1. That's why I ran 8/3 to my inverter and 6/3 out. I offer very low resistance and losses. I can now control the maximum amperage on the primary shore power line and dial it to exactly what I want to run, when I want to run it. My boat has two 30 amp shore power lines, but since I only occasionally get to run that much current into the boat, I've engineered the system so that I can run my daily loads on a 15 amp shore power circuit if I have to (or less). I make up peak loads by co-generating with the inverter and put the energy back at non peak times. I doubt I'll have to worry about the limitations of a single 30 amp cable again, but I still think its sad that the standard equipment sold for marine use is of such poor quality. I believe the 10/3 cordsets are not even made out of tinned copper!
