Slip Width
We had one of those slips with only 1 ft on each side and it worked fine.
Our only problem was the roof of the shed was 2 ft. shorter than the boat
and on a abnormally high tide, we couldn't get out of the boat shed.
In the winter, when I was gone for 2 weeks, we had green funk growing on
the front deck cause the sun couldn't hit there.
We moved to a longer and wider slip to prevent that. It is also a lot taller.
We had no other problems with the narrower slip.
We are in a very protected bayou and only have wind issues when the winds
are whipping hard from the West.
The width will be fine, I'd save the money. How is the water depth that close to the shoreline? I bought my boat last year on the Seneca Creek and the slips close to shore were subject to shoaling. That marina didn't dredge but yours may.
I have the choice of a 13' slip and a 10' slip. My boat is 8'6" wide. I have only been boating for a year. I guess I would be better off with the 13' slip if I understand everyone correctly. What do u guys think?
Chris - close to 9 feet in the slip I'm looking at. With only an 18" draft, I should be fine unless the entire Bay drains!
CaptNCamille - depends on your boat handling skills. A larger slip can actually be harder to dock in.
Your slip depth may be fine but consider the fact that if you get blown towards shore you could get into trouble. It looks like most boats bow in, which is alot easier to do than stern in, so if you bow in, no issue, but if you stern in and you miss, you could end upa few feet closer to shore which will change the water depth under your props. Just something to be aware of, probably a non issue.
If your tidal range (including wind blown "tides") is small and you do not depend upon your slip in storms than narrow (in comparison to your boat) slips are fine.
Last year I had my 10.5 foot beam boat in a 12 foot slip. One time after two or three days of north winds I actually had to cut one of the mid lines because the boat was actually hanging on that line. I also want to be able to leave the boat in the slip during "near miss" hurricane events. If a cane is projected to hit here I will try to find some place to haul the boat.
George
Kurt, My 8 foot beam is okay in a 10 foot 2 inch wide slip. If I can do it, you can. Spend the $$ you save on fuel. :)
Mixman, I"m still a novice, why would a larger slip be harder to dock in?
A boat will tend to "slosh around" an oversize slip. Line rigging becomes more of a pain. In a tight fit, the boat tends to "slot right in there", it is easy to get all lines attached and rigged. If you are in a calm harbor, tight slips are just fine, even if you have a few feet in tidal rise/fall ( less than a 4 ft or so range ). If you have larger tidal movement, a bit more room is desirable.
Really, as long as you can squeeze into it, just about any size will do, so there is little reason to pay form more than is required. One foot on all sides should be just fine. Note that the tighter the slip and the greater the tidal range, the more you will need adequate fenders...
In my opinion. I'm sure that there are others who will readily question my sanity...
--edit--
At 8.5 ft wide, you are trailerable and likely less that 28 ft in length. This also pretty much describes the overall design of the boat. And means that a slip 10 ft or wider will in most cases be exactly what you will want ( and get from the avg. harbormaster ). You will only get larger IF a) it's all he has left and b) you pay the higher price for an "oversize" slip. Remember that this is a real estate deal, and one foot extra on each side equals roughly 100 sq ft of rented water bottom... You will pay for it.
I had a 14 foot boat in a 15 foot slip for years. No problem whatsoever. I have snubbers on all lines. They are just short of taught during mid tide and stretch on the up and down. Boat never rubs or touches anything. I have no fenders at my home slip.
Considering Dominic is dealing with almost exactly the same tidal changes I deal with. I'm going with the narrower slip. Are you going to sell those snubbers before you head south? :-)
CaptNCamille - I agree with Bill. It's the "slosh" factor in a larger slip. I haven't had any problems for 4 years with the admiral with me and 3+ feet on each side. But when I single-hand the boat and the winds aren't just right, it can be a real ordeal to get things lined up right.
Dave - I hear you about the location of that slip and winds. But the fetch that would be required to knock me off target going in stern first just isn't very large. And if let's say both engines stall and I totally lose it (will there be a crowd around?? :-), we would end up on the beach. But the boat is beachable and the outboards tilt all the way up. I've probably got the best rig for such a slip anyway (which is why our club discounts it by $300/year I suppose).
lil red truck - And you've got more of a tidal flow up there in NY, right? Or are you on a lake?
Go with the concesus of opinions and save the money. The smaller width should not be a problem and if the lines are set up right will be easier to get in and out of with - no long reaches to a piling that is too far away from the boat.
"no long reaches"
Well, it's still a 30' boat in a 46' slip :-)
(I don't think I mentioned the length before)
Moved her into the narrower slip today. Granted, totally calm winds, but it was so much easier to hold her in place and get things done. The old wider slip was such a pain trying to single-hand. We'll spend the weekend doing our slip modifications and keeping an eye on the lines with this not-so-calm forecast:
SAT
W WINDS 15 TO 20 KT WITH GUSTS TO 30 KT. WAVES 2 TO 3 FT.
SAT NIGHT
W WINDS 15 TO 20 KT. GUSTS UP TO 30 KT IN THE EVENING.
WAVES 2 TO 3 FT.
