Decide on what you want to do with the boat and how solar power can contribute to its operation. While doing the initial restoration of the boat I had plenty of time to stand back and make a big-picture evaluation of how I wanted to use the boat. You may want to use solar power to trickle charge the boat while you are away during the week. I wanted a solar power system that would replace the power I used at anchor on a daily basis.
Think about the power you want in terms of amp/hours. Compared to a genset, the amount of power produced by a solar power system is pretty limited. I don’t know of many boaters who power a boat with air conditioning by solar. However, I know of several boaters who do power a refrigerator and the rest of the boat by solar.
Think of a solar power system in three parts: solar power storage (batteries), solar power collectors (solar panels) and the solar power controller (charger).
Batteries: This determines how much 12-volt power you can store on the boat. There are many choices: there are wet cell standard 12-volt batteries (starter batteries or deep-cycle), 6-volt golf cart batteries, 12-volt AGMs, dual purpose batteries, etc.
Panels: There are two basic kinds for marine use: rigid panels and flexible panels. Rigid panels feature the familiar glass and metal construction you see on home solar installations. These are modified for use on a boat. Rigid panels offer the best output power. Flexible panels provide less power output but offer serious installation advantages for smaller boats. Flexible panels offer lighter weight and can be strapped or tied onto the boat as needed.
Charge controllers: There is a basic rule of thumb: you will need to use a charge controller if your panels can produce 1.5% or more of your battery capacity in amps. For a 90 amp/hr battery, that's 1.4 amps or more. If you want a solar power system to trickle charge and maintain batteries over period of time you can get by with less than that 1.5% and not use a charge controller. If your solar system produces more than that 1.5% you run the chance of destroying the battery without a charge controller. A good charge controller with PWM charging will work like a good three-stage AC-powered battery charger and extend the lifespan of your battery.
An individual solution for every boater and each boat: For my boat, I decided to use the least amount of 12-VDC power I could get away with. Our boat has three group-27 deep-cycle batteries. To maximize the lifespan of these batteries, I never discharge them to less than 50% of the rated 90 amp/hr capacity. I figured a daily power usage of about 30 amp/hrs per day while at anchor. By modern boating standards, that’s almost nothing.
Two of the batteries are house batteries. While at anchor, I use one house battery for one day while the other is fully solar charged.
I installed low power lighting wherever possible. LEDs provide courtesy lighting so that I can get around the boat at night.
I hard-wired a Davis Mega-Light as a low draw anchor light. There are now LED anchor lights that will work just as well.
I replaced the household style 40-watt 12-VCD incandescent bulbs on the boat (common on old boats) with 12-Volt compact fluorescent bulbs that consume just 13 watts at 12-VDC, but produce the same amount of light as a 60-watt incandescent bulb (FEIT BPESL13T/MAR-12). These are getting hard to find right now:
http://www.blacklight.com/items/BPESL13TMAR12V
There is no waste holding tank on the old boat, so I installed one of the lowest-power Type I sanitation devices available: a Purasan Type I system by Raritan. Use of this system is EPA and USCG approved in my area.
No power-consuming refrigerators for me. I figure that a refrigerator requires at least 90 amp/hrs per day in my part of the country. Two six-day Igloo coolers with block ice work fine for six days on our boat: even with opening and closing and 90-104 degree heat during the summer. During our summers, covering the ice chests with wet white towels is a must.
Other power-saving necessities include an oil lamp for extra illumination and a non-pressurized alcohol stove.
Even with power usage limited to 30 amp/hrs per day, we still get to run the VHF radio, run battery-powered entertainment devices of all kinds, charge cell phones, read all we want day or night, watch TV, listen to CDs or catch a DVD during mosquito time.
I bought the solar panels four years ago and chose two Uni-Solar FLX-32 flexible panels. These panels features heavy-duty construction and weigh five pounds apiece. During northern California summers, this is about 64 watts total output or 30 amp/hrs of solar power per day. These panels tie onto the cockpit canvas of our boat. Because solar panels are a desirable target for thieves, I tie the panels to the canvas prior to making multi-day outings. It takes only ten minutes to install and hook up the flexible panels. I roll the panels into a one-foot diameter cylinder and store them safely after returning to the slip. Unfortunately, Uni-Solar discontinued production of these panels to concentrate on solar roof shingle production.
I helped in planning solar power installation for my in-laws last summer: again, using canvas-mounted flexible panels. For their 40-foot boat, I chose Global Solar GSE P3-55w panels in black. These can be folded and stored easily.
Compared to my older Uni-Solar panels, the GSEs offer nearly twice the power output for size and weigh less than two pounds apiece. Technology in this field is advancing every year. Note that due to high demand from the US armed services, the GSE P3 panel series may not be currently available. However, the GSE SL Sunlinq series is still available for non-service related purchase.
I like Morningstar charge controllers.
http://www.morningstarcorp.com/ Morningstar offers a wide variety of charge controller models. SunSaver 10 is an easy to use 10-amp PWM charge controller. Rated for explosive environments, it features a temperature sensor built into the unit. This small controller is mounted close to the battery bank. A green LED indicator light tells you the system is working: if you don’t believe it you can use a 12-VDC multimeter to run the tests.
The best part about solar power on a boat is the quiet. And the look on another skipper’s face when he sees you start your engine on the first crank after he’s watched you sit at anchor for nearly a week without running any motors.
