Spark plug recommendation
t2626mb
Was told to try Champion Rv15yc4 plugs instead of the standard mr43t in my 37 seayay with merc 454. Was told better performance. I know if the plug gets too hot piston damage can occur. Anybody have experience with this plug? Am I taking a chance?
I like Champion, Denso and NGK.
http://www.sparkplugdepot.com/
I know there are heat controls that have to be considered, but I have to wonder how much is marketing.
Champion has one "industrial" plug that costs $30 a piece. No that's not a typo....Thirty dollars a plug.
I wonder what the NASCAR folks really use..... Not the sticker on the car, what's under the hood.
The mr43t is a marine plug. It is made out of a different alloy for corrosion resistance. Assuming the rv15yc4 plugs will actually give you better performance, at most it would be a few HP. I doubt you would notice the difference. The question is whether the corrosion resistance is more important than "better" performance.
heat range is important part of the selection of the plug. Dont change that unless there is a clear reason.
I used the RV15YC4 plugs on my 82 260 OMC at the suggestion of George Van Parys, he said it was an updated plug that was better suited for the fuels in use now. All I can say is that they worked just fine. I currently use the AC MR43T plugs on my 89 5.7's and they seem to work fine too.
Champs are not the plug they used to be. I went to NGK Iridium for my 454 (7.4 MPI) and I stopped buying plugs. The things last forever and run great. You usually have to order them from Sparkplugs.com or other sites as most auto supplies do not stock the correct ones.
Just used them as a recommendation for fouled plugs. Need to make sure they won't burn piston.
Merc replacement plugs are NGK. BR6FS.
Go with that one first ans see how you do. Should be fine.
Only plug brand I will every buy.
Champions are garbage, good for lawn mower.
