We have one also. We don't use it as much as you though. it has been good except for the water solenoids get stuck open. The replacement is easy, but a pain to say the least. Our cold water solenoid sometimes works correctly, sometimes it floods the drum when the unit is off. So we always keep the shutoffs off.
Yes, our unit drains over the side through a through hull. We always ask the marinas if it is ok to use prior to using it at a visiting marina.
we have the vented model.
