spotlight controls question
I need to swap out my spotlight on our bayliner. I don't want to have to also swap out the controls at both helm stations. Anyone know if, typically speaking, spotlight controls are universal between models and makes? If not I imagine it would just be swapping out the 12v wiring? Anyone do this on their boat?
My ACR RCL-100 spotlight with the remote box actually uses RG-59 between the dash control to the remote control box mounted inside the boat mounted near the spotlight. The spotlight to the nearby remote requires 6 wires to the remote box and the remote box gets high current 12VDC from my bow thruster battery bank. The dash control station gets it's 12VDC power over the RG-59 signalling cable.
http://www.acrelectronics.com/media/products/1457/2710201111467558/Y1-03-0141E.pdf
I would contact the manufacturer of your current spotlight and ask if your controls are compatable with their current models.
Tony who is the manufacture and what is the model number of your current spotlight?
I swapped out a Guest( not sure of the model) for a 6in Jabsco last week for a friend. The Jab only uses 3 wires plus power and ground. Very easy only took 40min. The hardest part was using a hole saw( and this wasnt hard) to cut the new hole for the Jabs controls. I have done two of these and it was painless! If you are not comfortable with the saw you can use a Go-Light. All they need is Power and Ground. The remote it wireless!
Not a direct answer to your question, but I have found a hand held light to be more intuitive and easier to operate than a fixed, remote control light.
Just a thought.
Just a thought.
I really agree with you on this! However I have to remember to charge the high intensity LED handlight.
It's a Jabsco model 61040. I talked to them today...sounds like the controls are different now and I would not be able to swap them out without redoing the controls- more work than I want to get into.
I found a used one for sale- may go that route.
I agree the handhelds are often times easier- I have a very powerful recharable one that I really like. That is fine when I am on the bridge but when at the lower helm I would blind myself off the reflection on the glass so I would like to have the remote control one working for use at the lower helm and then can always use the crazy bright handheld when on the bridge.
