Spring recommissioning
Got this from Progressive, my boat insurance company.
Your Mission: Recommission!
Can you feel it? Spring is in the air-the birds are singing, the mercury's rising and that boat of yours is just begging to be taken for a spin. Although the season's boundless sense of promise might tempt you to run yodeling down the docks, reining in that enthusiasm for juuust a little longer will pay off in the long run. Taking the time to recommission your boat with basic preventative measures will ensure that nothing stands between you and boating bliss. Not even a lack of yodeling ability.
As you begin the recommissioning process, take some time to review your boat insurance policy. Progressive stands out for providing not just exceptional coverage, but also attentive customer service. Progressive's specialized policies offer optional features, like roadside assistance and on-water towing. Progressive customers enjoy unparalleled peace of mind, knowing you've crafted a policy that's best for your boating lifestyle; but there's no harm in taking actions that will prevent any possible problems from occurring in the first place.
For help understanding the steps for proper recommissioning, Progressive turned to the boating experts at Bayliner, boat builders for almost 50 years, to help guide us through the process:
How much service is required at the start of the season depends largely on the length of non-use, and your thoroughness in decommissioning last year. Wise boat owner that you are, we'll assume your winterization was nice and thorough. In fact, we'll assume you enlisted the help of a pro-and encourage you to do the same this spring. Dealers are your best source for assistance in this process – they know your boat and engine well and can easily walk you through the steps of recommissioning.
If you prefer to do it yourself, working from the outside in, detail your boat's exterior before putting it in the water. This will save you a lot of hassle later. After all, once you put it in, you're not going to want to take it out. Assess your bottom paint coat, repainting as needed. Wash the hull using reputable cleaning products and give it a fresh coat of wax.
Preserving your canvas and, particularly, your isinglass (if you have it) is another easy preventative step. If they've been rolled up all winter, they can become brittle and likely to bend or crack if unrolled cold. Bring them in and let them warm inside your home or car for a while, and they'll be properly flexible.
Recommissioning is also prime time to make sure your boat's battery is in ship-shape. Be sure your battery is charged and the connections are clean and tight. A CO alarm and a radio's memory can drain a battery during the storage months so much so that your boat may not start. Once your battery is fully charged, be sure it's topped off with distilled water.
Of course, the most important checks you'll make pre-season happen in the engine compartment. Inspect wiring and electrical connections to ensure rodents didn't pay a visit during the off-season! Spring is the perfect time to make sure all fluids are back to operating levels and to check the drive oil in the stern reservoir, especially if you didn't when you winterized. Be careful to make sure all batteries and generators are turned off during this inspection. Now is also a good time to change wear items such as spark plugs and fuel filters. And, to easily avoid overheating, ask yourself if it's time to replace the impeller.
If you tow your boat, don't forget to service your trailer. Check the tires and the spare for proper inflation, grease the wheel bearings, check the lights and, if equipped, the brakes. And lastly, perform a thorough inspection of the trailer frame.
When the precious moment arrives to fire 'er up, run the engine at idle speed for a few moments to warm it to normal operating temperature. Check for proper operation of the cooling, electrical and warning systems. Ensure that steering and engine controls operate freely. Finally, verify that the drain plug is in-common sense, yes, but a serious case of the spring antsies can make a boater forgetful. Give your boat the loving attention it's used to getting, and you'll be rewarded with endless hours of nonstop fun in the sun.
No matter how much experience you have, it’s always a good idea for everyone to review boating safety rules before departures. Read below to familiarize yourself with these 10 basic boating safety tips:
1. Be Weather-wise
Always check local weather conditions for boating safety before departure- TV and radio forecasts can be a good source of information. If you notice darkening clouds, volatile and rough changing winds, or sudden drops in temperature, play it safe by getting off the water.
2. Follow a Pre-Departure Checklist
Proper boating safety means being prepared for any possibility on the water. From compliance with fire safety regulations to tips for fueling up, following a pre-departure checklist is the best way to make sure no boating safety rules or precautions have been forgotten.
3. Use Common Sense
One of the most important parts of boating safety is to use your common sense. This means operating at a safe speed at all times, especially in crowded areas. Be alert at all times, and steer clear of large vessels and watercraft that can be restricted in their ability to stop or turn. Also be respectful of buoys and other navigational aids, all of which have been placed there for one reason only- to ensure your own boating safety.
4. Designate an Assistant Skipper
Make sure more than only one person on board is familiar with all aspects of your boat’s handling, operations, and other boating safety tips. If the primary navigator is injured or incapacitated in any way, it’s important to make sure someone else can follow the proper boating safety rules to get everyone else back to shore.
5. Develop a Float Plan
Whether you choose to inform a family member or staff at your local marina, always be sure let someone else know your float plan in terms of where you’re going and how long you’re going to be gone.
A float plan can include the following information: name, address, and phone number of trip leader: name and number of all passengers; boat type and registration information; trip itinerary; types of communication and signal equipment onboard.
6. Make Proper Use of Lifejackets
Did you know that the majority of drowning victims as the result of boating accidents were found not to be wearing a Lifejacket? Make sure that your family and friends aren’t part of this statistic by assigning and fitting each member of your onboard team with a Lifejacket-prior to departure.
7. Avoid Alcohol
Practice boating safety at all times by saving the alcohol for later. The probability of being involved in a boating accident doubles when alcohol is involved, and studies have also shown that the affect of alcohol is exacerbated by external effects such as sun and wind.
8. Learn to Swim
If you’re going to be in and around the water, proper boating safety means knowing how to swim. Local organizations such as the American Red Cross and others offer training for all ages and abilities- check to see what classes are offered in your area!
9. Take a Boating Course
Beginning boaters and experienced experts alike need be familiar with boating safety rules of operation. Boater education requirements vary by state- some require validated completion of at least one boating safety course. Regardless of your individual state's requirements, it's always important to be educated, aware and prepared for every circumstance that might arise. You can learn boating safety rules by taking a local community course, or there are online tutorials to help educate novice boaters.
10. Consider a Free Vessel Safety Check
Take advantage of a free Vessel Safety Check from the US Coast Guard (see links below). They offer complimentary boat examinations to verify the presence and condition of certain Safety Equipment required by State and the Federal regulations. Free of charge, they’ll provide a specialist to check out your boat and make helpful boating safety tips and recommendations. They also offer virtual online safety checks as well. Find a vessel Safety check examiner closest to you.
REcommissioning always sounds like I did it wrong the first time and I had to do it again!
Those were from an email I got from Progressive.
Thought it was kinda funny they are sending out recipe's.
I am a pretty good cook. I catch, clean and cook my own fish.
