I had a problem with the starboard engine lagging the port side in terms of WOT by about 300 rpm or so. Did all the electrical/fuel tune-up stuff.
So when I hauled the boat to paint it recently, of course I took a close look at the props, and in fact the starboard side had some pretty good nicks.
So I decided to replace them both. Now the boat came with an extra set, which had been re-done by some prop shop (not sure which one, no way to trace) by the prior owner.
Problem now with the 'new' props is this:
When going on plane, the starboard engine revs too high and whines, goes right up to about 5,000 rpm (previously 4,000 with the old prop) in an awful hurry, before I back it off, then it sort of seems to settle in.
Also, port prop just seems to 'bite' more. Starboard doesn't seem to be catching as much of a load, if you know what I mean, until it sort of 'settles in' after first whining up to 5,000 rpms (I've only tried this a couple of times, and obviously don't intend to keep doing it...).
Seems like what a 'spun hub' should feel like, based on other posts, but as I've never had one, thoughts appreciated...
And if it is, is it difficult to change the prop while the boat is in the water? I can back it into my slip stern to, should be able to get at it, but that said the water is about 50 degrees here...
What's the procedure for pulling the prop, and is it different if the boat is in the water?
Thanks a lot.
Orcbait
Thanks a lot.
Orcbait
