Stainless Props?
Tanqueray
I spent the past few days taking the paint off my Stainless Steel Props that's been on there since I brought the Boat home from Florida 5 years ago. The previous owner had painted them black and apparently had put some sort of a red primer (?) on first. I finished one pretty good the other day and started the other one yesterday and was going to put them back on today in preparation for a Thursday Launch......well the one I did first now looks nothing like it did when I finished it (and I kept them in the house) but it more resembles a piece of sheet metal that's been left out in the yard for a year or so. Looks all rusty and funky brownish looking. Anybody have any ideas as to how to get the shine back on them? These look like no Stainless Props I've ever seen. All the ones I've ever seen looked like the ones Bob is trying to sell. These look more like something salvaged from the scrap yard.
Yikes, that's not right. I wonder if they're really stainless steel? I thought paint wouldn't stick to stainless?
That's what I thought too but maybe the primer (?) or whatever the red stuff under the black paint was helped it to adhere?
I had somebody else also tell me that these aren't Stainless Props so I asked him what they were and his response was...."Well.........ah dunno. They're not Aluminum but they're not stainless"
So okay....If they're not Stainless....then what are they?
They weigh 18ounds each and that's way to heavy for them to be aluminum. Plus a few years ago we ran over a submerged something floating in the river which stopped the prop momentarily and broke a tooth in the upper case of the outdrive and didn't even ding the prop. Had these been Aluminum it would have wiped out a blade or something before it did that type of damage.
If you had used aluminum props, you would have either had to rework or replace the prop and not have any damage to your outdrive. I prefer aluminum props where I boat.
I realize that Flutter and that actually was my point in people telling me that these aren't Stainless Props.
So if they're NOT.....then what are they....I just took a pic of the one that's been sitting for a few days in the house. Tell me this isn't wretched looking.
And again...if that's not stainless...then what the hell is it?
Maybe a very poor quality steel which appears to be stainless when new? Just a guess! There are different grades of SS......
what did you use to clean them? steel brush? Wire wheel?
BACK IN THE OLD DAYS ALL SS PROPS WERE COATED WITH A BLACK TIFLON
Soak them in a tub of water (about 1 hour) with about 1/2 cup of murriatic acid
Will look like btand new.
They look like brushed stainless, they will never have a "bright finish" just clean.
Abouttime
Does a magnet stick to the props? I believe a magnet will not stick to good stainless.
That sure looks like stainless. Bravo III, right? any part number on them? Do they say "Mercruiser" on them?
Stainless with the start of crevice corrosion cause they were painted?
I used Sandpaper.....a Wire Brush.....A Wire Wheel......Muriatic Acid....an aggressive Rubbing Compound......Oven Cleaner......You name it...I've used it.
In fact I let it soak in Muriatic Acid (NON-Diluted) for over 4 hours and THEN had to use the Wire Wheel on the end of a drill AND Sandpaper and they look fine for about 15 minutes. Then they look like this 15 minutes later.
I've tried just about everything I can think of....
Maybe I'll try setting em down in the driveway and throwing rocks at em.
Tanq,
This is a good question. (edit-saw your post)
My B3 props were "brushed" stainless. Used a steel brush once to clean them and had that look. After that, I used very fine grit (1800 ?) wet paper and they would not feel smooth after a few days in the water. Finally had them to the prop shop and properly pollished. No issues after that.
http://www.mercurymarine.com/serviceandwarranty/mercruiserfaqs/propping.php#1142
(Edit-information about stainless props and rust)
Stan
if the wire wheel and OR wire brush had previously been used on other rusty NON stainless it will cause the stainless to rust. Maybe the previous owner did exactly that and ended up painting them. You need to use NEW and Dedicated wire wheels for stainless, can't go from non stainles to stainless with out transfering rust to the stainless.
And this from the Mercury Marine site (thanks for the link by the way)
"The propeller can be easily cleaned with rubbing compound or Scotchbrite. Do not use steel wool. After cleaning, use chrome polish to protect the finish. Stainless steel props can also turn white from calcium or lime in the water. In this case, clean the prop with household mineral bath and tile cleaner. Again, do not use steel wool"
Once again it appears I was the creator of my own demise. I see there that it specifically says NOT to use Steel Wool. Well I guess a wire wheel and sand-paper are somehow the almost equvilant of these items so I guess I'm just stuck with the looks. Thank God they're hidden under the Swim Platform where nobody can see em which is probably why I never did this before. I juswt thought that this year I'd clean up some stuff that I was always....'was-gonna' do.
Here is some technical stuff, some may like. The "rust" stains are highly probable from imbedded iron particles from previuos transfer. It could have been a contaminated abrasive, brush, steel wool, grit blasting prior to paint, etc.... It could be localized corrosion caused by the paint overlay. SS needs oxygen exposure to retain its passive layer. This passive layer prevents further corrosion. This is why SS should not be used in underwater applications. Hull stringers and the like. Bronze or Nickel are better. Most Austenitic Stainless Steel ( 300 series) is non-magnetic, depending on how it was formed and processed. 300 Series SS IS much softer than 400 Series and Duplex types. These types have more iron and are generally stronger, but also rust more. The Prop is definately marketed as a SS alloy, which is correct using the broad definition. The Muriatic acid mentioned above dissolves the free iron on the surface. This eliminates the surface rust, normally called "Passivation" or "Electropolishing"
If you use ANY type of steel wire brush, wheel or wool, you will imbed iron particles in the surface. It will rust almost instantly. Use some 600 grit wet/dry sandpaper WET and you'll get most of that off. A dilute solution of Nitric Acid will work better than muriatic (hydrochloric) but the HCl is easy to find in any pool supply place
BTW, there is nothing wrong mechanically with that prop, it's only cosmetic. Stick it under the swim platform and put it in the water. Then forget about it until haul-out time next winter.
