Stalling
I have a 1982 cobia odessy 19.5 I/O with a 4 cyl 170 merc-cruiser. The son, and I are slowly making it "sea worthy".
Question... what would cause the boat to run for what seems like a set amount of time (20 - 30 minutes) in the water regardless of running at full throttle or just idling along,then sputter out (almost sounds like it is missing)and then die. Then on the restart it wont throttle down to an idle with out running rough and stalling, and you can not put it in gear and try to throttle up with out it stalling but it will restart each time. Then just let it sit for 30 minutes or so (fish in the mean time) start it up, it idles down, you can drop it in gear and throttle off like nothing was wrong.
Hours on the engine are real low based on some tell tail signs e.g no heat distortions signs,fluids clean etc. We did a lot of hull/ cosmetic work but the only thing we did drive train wise was replace the water seperator, replace the fuel lines, cleaned the screen filter on the carb, got out as much gas as possible from the tank then filled it an added dry gas.Plus replaced the outdrive impeller because it was overheating on the maiden voyage.
Any thoughts?
Probably not solve your problem--but you added "Dry Gas", which is an alcohol additative. Does the gas already have alcohol in it? (Ethanol).
This may actually be compounding the problem. You may have stirred up some sediment in the tank--and the alcohol actually may have contributed to bringing this material into the fuel.
The problem sounds temperature related--check the temperature--(with a thermometer, the guage may not be accurate enough) and see if the thermostat is working properly.
Connor, I had a similar problem with my 1985 - 350 Mercruiser with a carb. Check to ensure your choke is opening up properly. The choke on mine is mechanical (it opens as the engine temperature increases). The coil mechanism was not expanding as it should have which caused the engine to 'choke' out.
It's worth a look.
Bcat
