Originally posted by mf15
Looks like you are going to have to go shopping for a harder drill bit. Cobalt bits should not be to difficult to find.
Actually about two years ago my son broke off an easyout in a bolt in his bobcat, I went and bought other drill bits and we were able to get the easyout out, but can't remember if we drilled through the easyout or not. Old Mike
Drill-bit Type Comments
High Speed Steel (HSS) Twist Bits: Designed for metal and most plastics, these bits work reasonably well in wood, and if you are on a budget, these are the ones to buy. Most metals and plastics form swarf well, (swarf is the curl of metal or plastic that spirals off during machining) and this travel up the flutes (the helical grooves up the side) of the drill-bit fairly freely. Wood, on the other hand forms sawdust, and this tends to "choke" the drill. Hence, it is necessary to use a pumping action with these drill-bits in wood. This is particularly important with the smaller sizes as not only are they easier to snap, but more inclined to choke. If you are drilling metal, the swarf may be very sharp, and the hole edges may be too, so watch your fingers. Drilled holes in metal should have the sharp edges deburred using a larger hand-held drill-bit or a special deburring tool.
Coated HSS Drills For those of you intending to do a lot of metal drilling, drill-bits coated with Titanium Aluminium Nitride (TiAlN) can be a worthwhile investment. This is a golden colour (but beware, some of the super-cheap ones are simply flash-plated gold, or even painted gold!)
The coating is applied by vapour deposition and is hard, tough and has a low coefficient of friction. Normally high speed steel drill-bits do not drill aluminium gracefully (it tends to weld itself to the drill-bit, resulting in poor swarf clearance and a badly toleranced hole, either oversize, out-of-round or both). With TiAlN the low coefficient of friction eliminates this, and most metals can be drilled without coolant/lubricant. On top of this, faster cutting speeds can be employed and the tool life is about 10 times that of HSS. Obviously the price is higher, but industry seems to find it cost-effective, including less interruption for changing the bit.
Cobalt Drill-bits Another variation on the metal drilling theme. Cobalt drill-bits are the next step up the hardness scale from HSS drill-bits. They are designed to drill very hard materials, and will cope better with metals like stainless steel (although will still be blunted by some types). One useful DIY application is drilling out the remains of other broken drill-bits, although other harder bits may be better still.
C1150 The next harder step up is called a C1150. This has short flutes and a longer shank than normal. After this in hardness comes a D200 twist drill-bit.
D200 This looks quite a lot like a HSS twist drill-bit, so you have to look at the packet it comes in. It is quite a good drill-bit to have for stainless steel.
Solid Carbide Drill-bit Now this is a beast. It will drill and cut into a screw and stud extractor (also known as an "easy out") — an extractor tool for a broken stud/bolt, and these are made from quite hard steel in their own right.
There is also a fair chance that it could cut into any of the above drill-bits, if you could keep it on centre
