Starter
dsantos
Can I switch over to a starter with a 9 tooth drive gear from a 11 tooth drive gear? I have a Merc. 350 with a 12.75 flywheel and a small body starter which has failed again, I would like to change over to a large body heavy duty starter.
A 9 tooth starter will give you the lower gear ratio so why not. Just make sure the have the mounting bolt holes lined up as opposed to the 14" flywheel starter which off-set.
