The Piddler
- Jul 9, 2007
- 27335
- 1
I have replaced the Racor filter and cleaned the bowl, engine shut down after approx 5 miles of running. Then i replaced the primer bulb because i noticed it was soft. Same thing happened, after about 5 miles, slow loss of rpms, then shutting down, looked again and found new bulb squished flat. After about 10 mins the bulb had round ahape again. What to do next? I have a pair of 2000 150hp Evinrudes, the port motor is running smooth as silk, both engines pull from same tank.
