steering probs
stevejay
ih i have just fitted my evinrude 90 v4 to a glastron mid 80s 18 foot boat it is fitted dead center of the transom when at speed the steering is realy hard to turn right and the boat tilts to the left anyone help please
Adjust the trim tab behind the prop or better yet install hydraulic steering
If it's hard to turn the motor to the right (but ok to the left) it would be the trim tab behind the prop.
If the boat tilts to the left stopped or going slow you have a balance problem; move some weight around to get it to sit level.
Being an older boat the bottom could be deformed. Inspect it while it's on the trailer.
Originally posted by November Charlie
Rack steering ?,
it has cable steering mike and when over 25kts is raly hard to turn right at low speed is ok
Moving the aft edge of the anti-steering torque ("trim")tab on the anti-cavitation plate a bit to the port side should reduce the tendency to pull the wheel to port.
Also, remember trimming the engine/drive up or down effectively changes the prop pitch relative to the flow of water so when the prop is not level the effective pitch on one side of the prop will be greater and less on the other, and will tend to change steering torque. Trimming an O/B or I/O with RH prop down from level-shaft should tend to make the boat easier to steer to stbd,... trimming up easier to the right. Obviously this would be much more apparent with feedback cable steering.
