Stern in
dap
35'long 13'wide planing hull express twin v drive.
Must stern in starboard to dock finger which is 28' long.Port side boat 2' past his finger and 3' between us.Wind 90% of the time against my port side blows me past my finger before I can get backing in.Most times end up pivoting with my starboard against the corner of my finger dock creating headaches and frustration.
No other slips availible and boat to long to bow in.
Any hints or ideas for backing in.
With no wind which is rare its no problem.
I'm envisioning that you're coming down the channel with the wind, and that you pass your dockmate's boat before getting to your slip. Is that correct? So when you pivot your boat to back in, the wind just keeps carrying you beyond your slip. Yes?
If that's the case, it's not an easy slip to get into. Can you start your turn sooner, i.e. further upwind, so that you're more lined up with your slip by the time the wind blows you there?
You may have to give it some short shots of power to get the boat more authoritatively in position.
Nancy
Nancy
Yes I do start my turn sooner, but by the time my stern clears his and I start reversing my bow is gone to starboard pivoting around the corner of my finger.
Rudder to starboard, port engine reverse, starboard forward. Port reverse must overpower starboard forward, starboard forward only enough to hold her against the wind. Rudder to starboard to walk her against the wind
cant be reliably done. you need a pole. Will the marina allow you to install one?
SR360aft my boat is so flat bottomed it moves sideways very fast in the wind.
pdecat I assume you mean a pole out from dock corner,if so they will not allow it.
Does it make sense to BACK down the fairway to your slip? You'd have better control with the bow into the wind, and it might be easier to stop the boat in front of the slip long enough to pivot and get into the slip.
I've resorted to this technique a couple times and it's worked for me.
Dap,
I have the same set up. I inch down the fairway very slowly hugging my starboard side, the side I’m going to back into. As I slowly pass my slip, I start to reverse in bumps and using the shifters only (no wheel) maneuver (with authority) in the slip, narrowly missing my neighbor to my port and sometimes not using my finger to pivot. It takes practice and is better if my neighbor is slipped. It ends up being a 49 point turn, constantly bumping the shifters, usually in opposite directions to affect the desired turns.
I thought about backing down the fairway, but with the wind pushing you, when you start to back in, the wind will take your bow and blow it around.
If the finger is a floating dock with no piling at the outer corner, something like a Jim Buoy Dock Roller Bumper (up to 16" dia.) might help as judicious use of gears and throttle twist the boat around the corner and snugly in the slip, and definitely don't hesitate to employ Pascal's spring if you can handle it.( In this case from your stbd stern qtr fwd to dock outside corner until the boat is straightened out in line with the slip- much easier with handy mate who knows the plan.)
I would come down the fairway and pass by your dock. Pivot 180 degrees and head back with your bow to the wind. Back in and pivot around the corner of your dock. Have a line on your bow cleat ready to throw to someone on the dock or a deckhand ready to step off the boat to hold the bow.
I am thinking that this, or something similar, is a very good idea. Use that corner as a pivot. You may think it does not look professional, but who cares how it looks as long as it works.
Good luck.
G
I've had to do this many times docking single handed in a good blow. Don't be afraid to "goose" the engines a little to overcome the wind and start your boat turning.
In this same situation, I tend to slow to near a dead stop in front of my slip with both engines in reverse and my stern at what is the edge of the port side of my slip, then immediately put starboard in nuetral. This way there's no stop in the motion. If my bow is getting pushed toward the finger pier, I watch my port stern quarter (so I don't hit a post or other boat) and put starboard in forward. This pivots counterclockwise while continuing reverse motion. The rest is just fine tuning with a little forward and reverse action on both engines until I'm in. If the wind is still pushing me down the fairway, I give it a few RPMs during all this, but be careful not to over do it. Most times that I hear excess RPMs in the marina, it's just before a crunching sound.
hope that helps.
if i understand right the wind is blowing perpendicular to your slip pushing your starboard side against the finger.
i prefer to dock with this type of wind and do it by myself all of the time.
yes, put your bow into the wind, then i back into my slip at a 45 degree angle unitl the stern is in the slip, then i just back the rest of the way in on my port motor which will swing the bow in.
i do not try to line up and back straight into my slip with this type of wind, i stay at the angle to let the wind push my bow around as i am backing in...i use the wind to help me.
I think he said the wind is blowing him off his finger pier with only 3' between him and the next, down wind, boat. Any mistake or slow line attachment and one end of the boat or the other blows down a few feet into the adjacent boat. A pole between the boats would serve as a control point for rotation and bow control.
A line running along the dock to be grabbed with a boat hook and strong line handlers may help but in a heavy wind it will always be difficult. As I see it a spring will help for a few feet but not backing 30' parallel.
If you put a good size dock wheel on the corner tip of you Starboard finger, as you come down the fairway pin your Starboard rear side end against the dock wheel and pivot in just using the port engine in reverse. You'll need about 4 to 6-ft of your stern in the slip against the wheel to make this work easy for you.
you can look at other boats in the same situation to see how they do it.
If you're not comfortable handling a boat that large in a slip that small, maybe you should consider getting a smaller boat.
Tend to agree with Bob, but that's not always an option.
Don't be afraid to use the corner of the dock as a fulcrum as long as it won't damage your boat. Look into the above-mentioned wheel if necessary.
Personally, I'd go a little past the slip then back up to it. As you turn the stern in the momentum should swing the bow out and help you line up. With a single (my boat) I'd need a spring or anchor to keep things under control.
I dont see the wheel as any help as the bow will swing down wind rapidly, controlling it will be the problem.
