Stern Thruster
jhc109
Last week when I tried to use the stern thruster I got no propulsion, just a high pitched whirring sound. Thoughts? Is the motor gone? I can't believe the blades/propellers are gone. Thanks
jHC
Have you checked / replaced the thruster anode regularly well before it is gone to help keep the shaft from corroding off?
You didn't say what you have, but Vetus says replace anode at least once a year and any time it looks more than 1/2 gone.
http://www.defender.com/images/products/vetus/thruster_maintenance.pdf
If yours employs a cotter pin outside the propshaft nuts & if that was not secured properly, the prop can be lost.
No matter what, if there is really no flow , it sounds like you or your diver should be going for an inspection dip unless you have an U/W camera you can lower to see if it looks intact externally.
If you heard a "high pitched whirring sound", I would think the motor is not "gone". I suspect the propeller may be gone though. You're going to have to take a look.
Sounds like the motor is running but the prop isn't. Either the prop is gone or the key or maybe an issue with the gear between the motor shaft and prop shaft
Just take a look, you ok know right away if the prop is there and if spins freely by hand, come on... Your homeport says newport, water isn't that cold in late July :)
I have Side-Power Thrusters. They use a small shear pin that is easily replaced from inside the boat. There is usually a spare attached. If it is broken, it will be obvious. It's very easy to check and replace on a bow thruster. A little tougher on a stern thruster because of the location and it's ignition protected. You didn't say what kind you have but check the manual to see if there is a shear pin on the drive shaft.
Thank you for your ideas. I have Side Power thrusters and it was a shear pin that was easily fixed. Thanks Michael. And Pascal.....it was a bad winter and the water is still a bit cold !
