still stalling
I logged in on the 13th with a 1981 odessy cobia 19.5' cuddy I/O 170hp merccruiser 4 cyl. Been trouble shooting a stalling problems.Up to last night I thought I was dealing with a carb/fuel issue. Now I am not so sure.
Recap on my last entry, start up and runs good in the yard,runs good in the water for 20-30 minutes high or low speeds temps run in the 160s which is good but suddenly it will throttles down itself and quits. You can restart but runs rough and wont idle. Like I said I've be thinking fuel I've replaced water seperator,lines,filters. I remembered last night that when I had it out for its maiden voyage it over heated (bad impeler in the out drive which I replaced). Its got the closed looped coolant system which of all the boat I have had I've never had a closed loop system.When I completed the impeller I refilled the coolant system and was on my way.
Is the temp gauge only monitoring raw water portion and not the closed looped part? I dont over heat but tonight I started it up in the back yard took the cap off the radiator let it run, saw a few smaller burps of air bubble, but after 20 minutes of running the collant never started circulating.
Do I have a stuck thermastat? I felt the risers they were hot, felt the heat exchange it was hot both ends,the main lines were hot but the two smaller lines that are right at both ends of the exchanger were cool and did not change the level of the coolant when I pinched them.
Sorry for the book I just wrote, but trying to collect some thoughs, and opinions.
CC,
Two of the lines (on a four banger I believe) coming off of the heat exchanger will be for the sea water cooling and will not change the coolant level if you pinch them off. You did not mention if you had water running into the lower unit to the exchanger or if you ran the motor with the closed cooing only. Everything will get hot if you did not run water to the exchanger. That is, everything except the sea water lines. I would change the thermostat and also pull the end cap off the exchanger to make sure it is not plugged.
Been a long time since I had one of those, hope that helps.
Connor are you thinking the '..throttles down by itself and quits" is because the engine is overheating, but the guage does not show it?
There should be a Temp sending unit in the Cyl Head up front near the T-stat somewhere. That should moniter the Engine temp.
You might have a partially open T-stat, but the engine would heat up quickly if you did.
If you are handy with a Meter, you can monitor the sending unit (from cold to warm or hot) to see if its working at all
Its easy enough to pull the T-stat out, use your side-cutters to distort the valve a bit
so the Valve will not go down inside the rim and stick.
Look at your spark plugs. See if they are burnt blue. Overheated plugs from running lean will be blue as if you heated them with a torch.
Lean will cause the engine to quit sorta slowly. Re-starts after is sets long enough for you to take a look. But will overheat again soon and quit.
If you have Points, maybe your Condenser is over heating. If no points, maybe the coil is overheating.
More description would help. Assuming it is not locking up from overheating remove the gas tank cap to check for a plugged vent then look for a bad electrical connection dont forget the battery terminals. Darn near every running problem can be fixed with a new set of points though. If they arent new start there, if they are change the condenser and check gap anyway.
Thanks Donald,Thudpucker (sorry didn't see a name), and Bruce
1st I did have the water running into the lower unit, points are new,plugs are real clean but not blueing. I am going to go with a little from everyone.
Change out the thermostat (group agree)
Pull the end cap on the exchange and check for blockage
Change the condenser, and might as well change the coil while I am there.
Doing the four things all at once might not nessesaraly help me determine which one worked if it does straiten out the problem. However, that will be four more things that I have my own history on (one of the set backs of buying a used boat...zero history).
I will let you all know how the "fix" goes.
Thanks for replying
More fun!!! Went to step up on the outdrive this morn, and noticed some white foam. Sure enough I checked the outdrive oil overflow and the gear oil is a white cream (water in the gear oil). Even thoough it is another set back for me it is not in somehow realate to the stalling issue Im having. Could not see how but???
Only way I could see stalling would be if the drive had gotten so tight from lack of lubrication that it would stall the engine at idle. Pull it and get it checked, pressure tested, watch for water damage in the U-Joints and input shaft yoke as well as more obvious places like fish line in the prop shaft seal. Outdrives are expensive to repair, and letting rust take hold makes it all the worse. I was able to fix outboards that came in with water in the gearcase, not even oily. Just don't put it off.
Lack of lube could cause overheat causing a stall there are rarely multiple causes of a problem, usually just one. Fix the drive and see.
