Strange GPS behavior
Silver Duck
Every so often, the display on my Standard Horizon CP175C reverts back to the image it would have if I didn't have my C-Map chip plugged in.
It seems like the only way to restore the detailed display image provided by the C-Map chip is to zoom out to a range where the chip image wouldn't be used, then zoom back in.
I've tried powering down and back up to reboot, and that does not fix the situation, so I don't think that it's being caused by a bad connection.
I've also tried removing the chip and re-installing it, both in the same slot and in the second slot, and that doesn't fix the situation, either, so I don't think that it's being caused by a loose chip connection.
Also, mechanical vibration doesn't seem to be the cause, since this occurs even when at anchor.
Does anybody have a feel for whether this is a problem with the GPS, a problem with the chip, or just normal behavior? (I'm fairly certain that I saw a dockmate's CP180 do the same thing).
I'd like to get this taken care of over the Winter, if there's anything that can be done about it, but I don't know whether to send the GPS for service, or the chip for replacement!
Thanks for any advice,
Silver Duck
There are updates for that unit. Make sure you've downloaded them all. And I'd call Standard tech support - they may have experienced similar behavior. I doubt if it's the cartridge. Not much going on there but memory storage.
