Hi,
Well I went down to the boat today to check on it, and was met by something new in the cabin.
2 long wrinkles on the corner of my cabinets.
I can't see where anything has leaked in, and I am baffled as to why or how this happened. A week ago it was not there.
My wife is heartbroken as this boat is 12 years old, and the interior is still perfect. (Until Now)
I've attached a picture of the area, but this was taken prior to the problem. When I go back down, I'll attach a current picture.
The wrinkle is about 1/2" wide, and is located in the center of the circle I've added to the picture. The entire length of the corner. If you notice the two areas are not even connected, but both are now deformed. It's as though you pinched or pulled out the corner all the way down, if you can picture that.
Next question is, what is the surface called and can it be recovered?
Thanks for any info.
