I'm in the process of replacing my vinyl stripe which is 4" wide. There are a total of 11 thru hulls which pass through the stripe at some point. All are above but close to the water line.
Is it better to remove enough of the stripe around the thru hull so that the sealant and thru hull makes contact with the gel coat, or to just cut away enough of an opening to install the thru hull? In this instance the thru hull would actually be positioned over the tape.
