Striping
Searay Fool
I recently had to remove some old striping from my 1989 280 Sundancer. I'm sure it was original, but had gotten pretty bad. I got it off with the help of a hair dryer, but does anyone know what to use to remove that darned glue?!
Acetone or GOO B GONE. Test in a small area to make sure it does not hurt your finish.
Ken
Hey guys, I found that Gumout Carborator and Choke Cleaner works even better. I used a good polish right after and there was no ill effect to the gelcoat.
Thanks again for your help.
Good to hear you got it off. I was aware of that method however, I am reluctant to recommend the stronger removal techniques. Some people do not use strong chemicals on their boat.
I took mine off as well. Not replacing it. I think it modernizes the look.
3M makes an adhesive remover in an aerosol can. I found it worked better than WD-40 and goo gone removing the old name off of transom.
Originally posted by Searay Fool
Are you going to put the striping back on your boat? If so, have you found a source for the striping? I am thinking of doing the same thing as mine has faded in the Florida sun, but I am not sure where to get the striping material.
About 6-7 years ago I had a 1991 280DA that I wanted to re-stripe also. I searched for awhile and couldn't find any replacement stripes.
What I ended up doing was taking a piece of the original stripes to a local sign shop that works in vinyl..... he duplicated the sizes and color and made me up a few rolls. I installed it myself.....it looked great.
I sold the boat to a buddy of mine....and the stripes still looks good.
Never buy Goo B Gone. You can buy Xylene. It is virtually the same.
