Stuffing box leaking 101
rfeeney
If your stuffing box is leaking more than it should, how do you tighten? Do you tighten the hose clamps (2 of them) on the outside of the rubber sleeve? Do you tighten the 2 screws on the top of the cap (inside rubber sleeve) to compress the stuffing? Or both? Insight appreciated. Thanks
you never touch the clamps or the rubber hose...
some stuffing boxes have a big nut around the shaft, others have a stud on each side with nuts. that's what you tightned to compress the stuffing.
it's pretty obvious when you look at it. unless you have one of the modern dripless units which can't be adjusted and shoulnd't leak
The clamps should always be tight. To stop a leak from indide the stuffing box itself, you must first back off the lock nut ( the one closest to the rubber hose) then tighten the shaft nut. The while holding the sgaft nut, retighten the lock nut up against it. Check this link out. It may help you:
[http://www.pbase.com/mainecruising/stuffing_box]
Hope it helps.
cam
To stop the leak, you tighten the packing nut, further compressing the packing material. Don't tighten it too much or it will overheat while you're underway (you want a couple drops per minute underway). If the packing material is in bad shape, you may need to repack it. Here's a picture of mine. The packing material is inside the packing nut. Mine are notched nuts, but most look like regular hex nuts. It may take some effort (and maybe some WD40 or similar) to break the checknut free.
