Stupid(?) Question
jeffreytcole
Ok, you guys are probably going to laugh me off the forum for this but does anyone know how to tell what type of outdrive is on a boat by looking at it? I've got it narrowed down to Volvo Penta DP 280 or 290. I need to replace the zinc anode ring and there is a difference in the two so I need to figure out which one I need so I can order it. Thanks
well, what year? i had a 280 (1985), it had electric tilt (not sure if the later 290 had that or hydraulic), a plate on top of the drive (on the shift link cover) that said 280 :-) the top cover had an allen bolt at each corner and the dipstick in the center
why don't you google pictures or diagram? I'm sure there has to be parts diagrams somewhere on line that would let you ID the drive...
Thanks, that's what has me narrowed down to the 280 or 290 is the diagrams that I found I will do some more google'n though to see if any other diagrams come up
When will people figure this out? All questions are stupid! HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA!!!!!!!!!!!!!!!!!!!
The pics of most VP drives are on a competing marine supplier. Do a google search for "Volvo Penta Drive Finder" and you should find it.
The only stupid question...when it comes to boating safety & operation,is the one thats NOT asked
Originally posted by Thudpucker
That would explain some of the answers we get too!
Funny
Scary
If you look on the top of your flame arrestor, you sometimes can find a drive serial number. Take this number to a dealer and that will help you. The other suggestion I can make is that the anodes are cheap enough, buy one of each and see which one fits and then BLAMMO, you have your answer. Silly way to solve it, but it works! : )
Stupid and expensive answer to your question. You have it narrowed down to one of two drives. Could you buy a set of "zincs" for each and return the one that did not fit?
I've had both a 280 (1985) and twin 290 duoprops (1989). Besides the years, there are some differences. For example, th 280 had the electric tilt while the 290 had hydraulic rams for tilting. The 280 had a different style gear cover...the 290 had a taller cover which extended to the top.
Having been there and done that, your question is not silly....it's very hard to tell the difference.
Can you post a picture?
