6 golf cart batteries will only give you about 660AH rb2@gr5t 12v, or about 330AH usable. dont' know where you get your "2000 amp hours or greater total". Even if the two deep cycles were 8Ds, that's still just another 400AH or so. Plus, it's never a good idea to mix battery sizes in a bank, so i assume you have the golf cart batteries in a separate bank.
how many subzeros do you have? two of them? if you only run one, you may be able to get 15 to 18 hours, just.
on my boat, I run a full size 18cu ft fridge freezer fro about 18 hours, plus lights, TV, etc... on 8 golf cart batteries.
I installed a 4KW magnum and 16 Golf cart batteries on the 70 footer I captain and we get about 18 hours running 3 subzeros, 1 Uline Ice Maker Fridge, and the lights, TV, etc...
forget running air con on the inverter, you're going to drain teh bank very quickly, plus i doubt your 2000w inverter can power the subzero plus the AC together...
even if you could switch to 12v refrigeration, there is no miracle. it takes teh same amount of power to cool a fridge and freezer, whether at 12v or 120V. the only thing you may gain i eliminating the 10% inverter loss, but that's not worth it. jsut add another pair of batteries or two
