imspacemancraig
- May 24, 2009
- 31301
- 543
I have 1986 Crusaders model 270's (350's). I have been using straight SAE 30 oil since I bought it (7 years ago). Its also what the 1986 manual says to uses and I know the previous owners did the same.
I would like to switch to synthetic oil. Being older engines I know I can get better performance and cooling properties from the synthetics now. So the question is, which type?
On Crusader's site, they say to use 15w-40 for the summer climate I boat in. But I would assume that's for the newer engines they make. Would be reasonable to assume the same carries over to my 1986's?
I know that using the SAE30 I use now, I get the correct pressure when cold. Once warmed up, when under load its lower, but not as low as when at idle. Its not dangerously low, but I figured with the synthetic formulated to change when its warmed up, I could stabilize the pressures and most likely cool/lubricate better.
