There is a band playing at Tanner park that a friend wants to go listen to. Is it possible to anchor close to the park to listen to the band from the water?
Tanner is a big park, so I guess it depends on where they are going to play. If its by the beach, it would depend on wind direction. There is pretty good water in that area, hopefully you can luck out.
I took the boat to the beach behind the stage today and kicked up quite a bit of mud when I tried to get close to beach. I did not attempt to go up the canal to the west of the park, as Don recommends. Looks like weather may not be good Wed night for this U2 cover band, but we may try it at a later date.
