teak molding source
Well-known member
I am replacing some counter tops and need to find teak trim rails to replace the current rails in case I break them when removing. I can find everything except for two 45 degree inside and outside corners. They are similar to the picture except 45 degree instead of ninety degree shown any ideas where I can find these parts??
Did you contact your boat manufacturer? They probably have a woodworking shop which could supply you with the parts or refer you to their supplier.
Another option would be to find a local woodworking shop which can cut mouldings. They might be able to duplicate what you need.
Imported by AFI Seateak for most boatbuilders
google it, they have online sales.
As Gary said AFI, I have purchased them as well for a cockpit table
