I guess this is Vic's turf ...
Vic, after reading and comparing a lot about heads, I ordered two Atlantes A9's for my boat. I didn't choose the A8 because explaning "move the lever forward for long flush, move it backward for short flush" seemed a little confusing to me for guests on board (of which we have a lot) and I liked the "remote flush" feel of the A9.
I do have some questions about the touch panel, however:
The two heads where the toilets will be installed are located back to back. So the toilets are back to back as well, separated by a 3/4 inch plywood wall. I do not have the 2" space to recess them.
- Any way to reduce the touch panel installation depth?
- Can the touch pad case be opened and the wires diractly connected to the circuit board instead of using connectors?
- Is the touch pad a simple 4 switch on/off item or any electronic circuitry involved. In other terms can the touchpad be replaced by simple switches or if I do not want some of the functions (empty bowl) can the wires be reduced?
- Any other suggestions would be welcome !
