Can't remove temp sending unit on Crusader 350 HP 454. Won't unscrew. Tried penetrating oils etc. Anyone have any ideas short of drilling it out. If I have to drill it out what are the consequences?
Most likely you will end up snapping it off....just like I did a few years ago.
I ended up using a " reverse " drill bit that is used in easy-out kits. It looks like a standard drill bit....but its used in reverse. While I was drilling ( in reverse ) into the broken temp tube in the engine block......it loosened it up and came out on the drill bit...........
Don't know if it was luck....or it was the way it was to work.......but I was happy.
You could try a trick I used on an o2 sensor. Get a can of that compressed air that you clean computers or electronics with. Use a torch to heat (expand) around the sending unit. Tip the can of compressed air upside down and spray the sending unit and it will freeze (shrink) it. It could be enough to break it loose. The reverse drill thing works well but I worry about collateral damage to threads.
Carv....good point about thread damage..... you just need to use the smallest bit that fits in the coolant passage hole .....and take your time. When I got the broken tube out....I did run a bottoming tap down the threads...just to clean them up.... It never did leak.
Thanks for all the input. I have freeze off and will try it. If that don't work I will try the torch for heat and the feeze off for cold. Will let you know what works.
Freeze-Off may be the best "Penetrant" ever made but the demo showing the lowering of temperature was measuring the propellant coming out of the can which vaporizes immediately. Just my 2 cents !
